volume encryption secure-purge show
PDF of this doc site
Creating your file...
Show status of secure-purge operation on a volume
The volume encryption secure-purge show
command displays information about volume encryption securepurge operation in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver (privilege: advanced)-
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>]
- Volume (privilege: advanced)-
This parameter specifies the name of the volume being secure purged.
[-status {invalid|initializing|snapshots-deleting|snapshots-deleted|zombies-draining|zombies-drained|batched-free-log-draining|batched-free-log-drained|finishing-trash-purge|finished-trash-purge|reencrypting|aborting|aborted|success|failure}]
- Status (privilege: advanced)-
This parameter displays the status of the secure purge operation.
The following example shows a sample output for this command:
cluster1::> volume encryption secure-purge show Vserver Volume Secure Purge Phase ----------- ------------- ---------------------- vs1 vol1 reencrypting
