ONTAP 9.5 commands
vserver cifs domain name-mapping-search show
Display the list of trusted domains for name-mapping searches
The vserver cifs domain name-mapping-search show command displays information about trusted domains of the home domain by Vserver.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
This parameter specifies the name of the Vserver for which you want to display information about the trusted domains.
[-trusted-domains <domain name>,…​] - Trusted domains
This parameter specifies a comma-delimited list of fully qualified domain names of trusted domains for which you want to display information.
The following example displays information about all preferred trusted domains:
cluster1::> vserver cifs domain name-mapping-search show
Vserver         Trusted Domains
vserver_1       CIFS1.EXAMPLE.COM
