volume efficiency check
Scrub efficiency metadata of a volume
This command verifies and updates the fingerprint database for the specified volume. This command is not supported on FlexGroups or Infinite Volumes that are managed by storage services.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
Specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name (privilege: advanced) -
Specifies the volume on which the verify operation needs to be started.
-path </vol/volume>
- Volume Path (privilege: advanced) } -
Specifies the volume path on which the verify operation needs to be started.
[-d, -delete-checkpoint {true|false}]
- Delete Checkpoint (privilege: advanced)-
Deletes existing checkpoint.
The following example runs volume efficiency check
with delete checkpoint option turned on.
cluster1::*> volume efficiency check -vserver vs1 -volume vol1 -delete-checkpoint true
