      storage shelf location-led modify
Modify the state of the shelf Location LED
The storage shelf location-led modify command modifies the on/off state of the shelf location LED.
-shelf-name <text>- Shelf Name-
This parameter specifies the shelf whose LED is to be turned on or turned off.
 [-led-status {on|off}]- Location LED-
This parameter specifies whether the shelf location LED needs to be turned on or turned off.
The following example turns on the shelf location LED of the specified shelf.
cluster1::> storage shelf location-led modify -shelf-name 1.0 -led-status on Info: Shelf locate request successful for shelf "1.0".
The following example turns off the shelf location LED of the specified shelf.
cluster1::> storage shelf location-led modify -shelf-name 1.0 -led-status off Info: Shelf locate request successful for shelf "1.0".
