The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage disk remove-reservation
PDF of this doc site
Creating your file...
Your file is ready
Removes reservation from an array LUN marked as foreign.
The storage disk remove-reservation
command removes persistent reservation from a specified foreign array LUN.
-disk <disk path name>
- Disk Name (privilege: advanced)-
This specifies the disk from which persistent reservation is to be removed.
The following example removes the persistent reservation from a disk named node1:switch01:port.126L1.
cluster1::> storage disk remove-reservation -disk node1:switch01:port.126L1
