system health policy definition show
Display system health policy definitions
The system health policy definition show command lists the health monitor policy definitions as described by the health monitor policy file. The command displays the following fields:
Node name
Monitor name
Policy name
Policy rule expression
Expression for joining two tables
Policy status
Alert identifier
Responsible resource name
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects policy definitions for the specified node.
 [-monitor <hm_type>]- Monitor-
Selects policy definitions with the specified monitor name.
 [-policy-id <text>]- Policy-
Selects policy definitions with the specified policy identifier.
 [-rule-expression <ArithExpr>]- Rule Expression-
Selects policy definitions with the specified rule of expression.
 [-where <ArithExpr>]- Variable Equivalence-
Selects rules that match the provided expression. This expression is part of the alert definition. It is shown for reference only and cannot be changed.
 [-enable {true|false}]- Policy Status-
Use this parameter with the value set to "true" to select policy definitions that are enabled. Set the value to "false" to select policy definitions that are disabled.
 [-alert-id <text>]- Alert ID-
Selects all policy definitions of the specified alert identifier.
 [-responsible-resource-info <text>]- Table and ID of Resource at Fault-
Selects all policy definitions with the specified responsible resource.
 [-asup-enable {true|false}]- Enable AutoSupport for This Alert-
Selects policy definitions for which AutoSupport messages are either enabled or disabled.
The example below displays information about all the policy definitions present in the cluster:
cluster1::> system health policy definition show
Node          Monitor                Policy
node1         node-connect           ControllerToShelfIomA_Policy
Policy Rule Expression: nschm_shelf_info.num-paths == 2
                        nschm_shelf_info.iomb-adapter == NULL
                 Where: -
                Enable: true
              Alert ID: ControllerToShelfIomA_Alert
      Number of Alerts: -
  Responsible Resource: nschm_shelf_info.name
The example below displays detailed information about all the policy definitions present in the cluster:
cluster1::> system health policy definition show -instance
Node: node1
                          Monitor: node-connect
                           Policy: ControllerToShelfIomA_Policy
                  Rule Expression: nschm_shelf_info.num-paths == 2  nschm_shelf_info.iomb-adapter == NULL
             Variable Equivalence: -
                    Policy Status: true
Table and ID of Resource at Fault: nschm_shelf_info.name
