ONTAP commands
system health policy definition show
Display system health policy definitions
The system health policy definition show command lists the health monitor policy definitions as described by the health monitor policy file. The command displays the following fields:
  • Node name
  • Monitor name
  • Policy name
  • Policy rule expression
  • Expression for joining two tables
  • Policy status
  • Alert identifier
  • Responsible resource name
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects policy definitions for the specified node.
[-monitor <hm_type>] - Monitor
Selects policy definitions with the specified monitor name.
[-policy-id <text>] - Policy
Selects policy definitions with the specified policy identifier.
[-rule-expression <ArithExpr>] - Rule Expression
Selects policy definitions with the specified rule of expression.
[-where <ArithExpr>] - Variable Equivalence
Selects rules that match the provided expression. This expression is part of the alert definition. It is shown for reference only and cannot be changed.
[-enable {true|false}] - Policy Status
Use this parameter with the value set to "true" to select policy definitions that are enabled. Set the value to "false" to select policy definitions that are disabled.
[-alert-id <text>] - Alert ID
Selects all policy definitions of the specified alert identifier.
[-responsible-resource-info <text>] - Table and ID of Resource at Fault
Selects all policy definitions with the specified responsible resource.
[-asup-enable {true|false}] - Enable AutoSupport for This Alert
Selects policy definitions for which AutoSupport messages are either enabled or disabled.
The example below displays information about all the policy definitions present in the cluster:
cluster1::> system health policy definition show
Node          Monitor                Policy
node1         node-connect           ControllerToShelfIomA_Policy
Policy Rule Expression: nschm_shelf_info.num-paths == 2
                        nschm_shelf_info.iomb-adapter == NULL
                 Where: -
                Enable: true
              Alert ID: ControllerToShelfIomA_Alert
      Number of Alerts: -
  Responsible Resource: nschm_shelf_info.name
The example below displays detailed information about all the policy definitions present in the cluster:
cluster1::> system health policy definition show -instance
Node: node1
                          Monitor: node-connect
                           Policy: ControllerToShelfIomA_Policy
                  Rule Expression: nschm_shelf_info.num-paths == 2  nschm_shelf_info.iomb-adapter == NULL
             Variable Equivalence: -
                    Policy Status: true
Table and ID of Resource at Fault: nschm_shelf_info.name
