system controller config show
Display System Configuration Information
The system controller config show
command displays system configuration information for the devices present in the controller. To display more details, use the -instance
parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the nodes that match this parameter value.
[-device <text>]
- Device-
Selects the configuration information that matches the specified device.
[-subslot <integer>]
- Subslot Number-
Selects the configuration information that matches the specified subslot.
[-info <text>]
- Device Info-
Selects the configuration information that matches the specified device information.
[-slot <text>]
- Slot-
Selects the configuration information that matches the specified slot.
The following example displays configuration information for slot 1 of the controller:
cluster1::> system controller config show -slot 1 Node: node1 Sub- Device/ Slot slot Information ---- ---- -------------------------------------------------------------------- 1 - NVRAM10 HSL Device Name: Interconnect HBA: Generic OFED Provider Port Name: ib1a Default GID: fe80:0000:0000:0000:0000:0000:0000:0104 Base LID: 0x104 Active MTU: 8192 Data Rate: 0 Gb/s (8X) Link State: DOWN QSFP Vendor: Amphenol QSFP Part Number: 112-00436+A0 QSFP Type: Passive Copper 1m ID:00 QSFP Serial Number: APF16130066875 QSFP Vendor: Amphenol QSFP Part Number: 112-00436+A0 QSFP Type: Passive Copper 1m ID:00 QSFP Serial Number: APF16130066857 cluster1::>
