statistics-v1 nfs show-v4
Display NFSv4 statistics
The statistics-v1 nfs show-v4 command displays the following statistics about the NFSv4 operations on each node in the cluster:
Result of the operations (success or failure)
Total number of null operations
Total number of compound operations
Total number of access operations
Total number of close operations
Total number of commit operations
Total number of create operations
Total number of delegpurge operations
Total number of delegret operations
Total number of getattr operations
Total number of getfh operations
Total number of link operations
Total number of lock operations
Total number of lockt operations
Total number of locku operations
Total number of lookup operations
Total number of lookupp operations
Total number of nverify operations
Total number of open operations
Total number of openattr operations
Total number of openconf operations
Total number of opendowng operations
Total number of putfh operations
Total number of putpubfh operations
Total number of putrootfh operations
Total number of read operations
Total number of readdir operations
Total number of readlink operations
Total number of remove operations
Total number of rename operations
Total number of renew operations
Total number of restorefh operations
Total number of savefh operations
Total number of secinfo operations
Total number of setattr operations
Total number of setcliid operations
Total number of setcliidconf operations
Total number of verify operations
Total number of write operations
Total number of rellockown operations
Total number of total operations
Percent of null operations
Percent of compound operations
Percent of access operations
Percent of close operations
Percent of commit operations
Percent of create operations
Percent of delegpurge operations
Percent of delegret operations
Percent of getattr operations
Percent of getfh operations
Percent of link operations
Percent of lock operations
Percent of lockt operations
Percent of locku operations
Percent of lookup operations
Percent of lookupp operations
Percent of nverify operations
Percent of open operations
Percent of openattr operations
Percent of openconf operations
Percent of opendowng operations
Percent of putfh operations
Percent of putpubfh operations
Percent of putrootfh operations
Percent of read operations
Percent of readdir operations
Percent of readlink operations
Percent of remove operations
Percent of rename operations
Percent of renew operations
Percent of restorefh operations
Percent of savefh operations
Percent of secinfo operations
Percent of setattr operations
Percent of setcliid operations
Percent of setCliidconf operations
Percent of verify operations
Percent of write operations
Percent of rellockown operations
This command is designed to be used to analyze performance characteristics and to help diagnose issues.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays NFSv4 statistics only for the specified node.
[-result {success|failure|all}]- Result-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified result (success/failure/all).
[-null <Counter with Delta>]- Null Procedure-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of null operations.
[-cmpnd <Counter with Delta>]- Compound Procedure-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of compound operations.
[-access <Counter with Delta>]- Access Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of access operations.
[-close <Counter with Delta>]- Close Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of close operations.
[-commit <Counter with Delta>]- Commit Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of commit operations.
[-create <Counter with Delta>]- Create Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of create operations.
[-delpur <Counter with Delta>]- Delegpurge Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of delegpurge operations.
[-delrtn <Counter with Delta>]- Delegret Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of delegret operations.
[-gattr <Counter with Delta>]- GetAttr Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of getattr operations.
[-getfh <Counter with Delta>]- GetFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of getfh operations.
[-link <Counter with Delta>]- Link Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of link operations.
[-lock <Counter with Delta>]- Lock Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lock operations.
[-lockt <Counter with Delta>]- LockT Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lockt operations.
[-locku <Counter with Delta>]- LockU Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of locku operations.
[-lookup <Counter with Delta>]- Lookup Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lookup operations.
[-lookpp <Counter with Delta>]- LookupP Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lookupp operations.
[-nverfy <Counter with Delta>]- Nverify Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of nverify operations.
[-open <Counter with Delta>]- Open Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of open operations.
[-opattr <Counter with Delta>]- OpenAttr Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of openattr operations.
[-opconf <Counter with Delta>]- OpenConf Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of openconf operations.
[-opndg <Counter with Delta>]- OpenDowng Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of opendowng operations.
[-putfh <Counter with Delta>]- PutFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of putfh operations.
[-putpfh <Counter with Delta>]- PutPubFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of putpubfh operations.
[-putrfh <Counter with Delta>]- PutRootFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of putrootfh operations.
[-read <Counter with Delta>]- Read Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of read operations.
[-readdr <Counter with Delta>]- ReadDir Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readdir operations.
[-rlink <Counter with Delta>]- ReadLink Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readlink operations.
[-remove <Counter with Delta>]- Remove Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of remove operations.
[-rename <Counter with Delta>]- Rename Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of rename operations.
[-renew <Counter with Delta>]- Renew Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of renew operations.
[-restfh <Counter with Delta>]- RestoreFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of restorefh operations.
[-savefh <Counter with Delta>]- SaveFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of savefh operations.
[-secinf <Counter with Delta>]- SecInfo Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of secinfo operations.
[-sattr <Counter with Delta>]- SetAttr Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setattr operations.
[-sclid <Counter with Delta>]- SetCliId Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setcliid operations.
[-scidc <Counter with Delta>]- SetCliIdConf Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setcliidconf operations.
[-verify <Counter with Delta>]- Verify Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of verify operations.
[-write <Counter with Delta>]- Write Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of write operations.
[-relown <Counter with Delta>]- RelLockOwn Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of rellockown operations.
[-total <Counter64 with Delta>]- Total Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of total nfsv4 operations.
[-null-pct <Counter with Delta>]- Percent Null Procedure-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of null operations.
[-cmpnd-pct <Counter with Delta>]- Percent Compound Procedure-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of compound operations.
[-access-pct <Counter with Delta>]- Percent Access Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of access operations.
[-close-pct <Counter with Delta>]- Percent Close Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of close operations.
[-commit-pct <Counter with Delta>]- Percent Commit Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of commit operations.
[-create-pct <Counter with Delta>]- Percent Create Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of create operations.
[-delpur-pct <Counter with Delta>]- Percent Delegpurge Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of delegpurge operations.
[-delrtn-pct <Counter with Delta>]- Percent Delegret Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of delegret operations.
[-gattr-pct <Counter with Delta>]- Percent GetAttr Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of getattr operations.
[-getfh-pct <Counter with Delta>]- Percent GetFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of getfh operations.
[-link-pct <Counter with Delta>]- Percent Link Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of link operations.
[-lock-pct <Counter with Delta>]- Percent Lock Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lock operations.
[-lockt-pct <Counter with Delta>]- Percent LockT Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lockt operations.
[-locku-pct <Counter with Delta>]- Percent LockU Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of locku operations.
[-lookup-pct <Counter with Delta>]- Percent Lookup Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lookup operations.
[-lookpp-pct <Counter with Delta>]- Percent LookupP Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lookupp operations.
[-nverfy-pct <Counter with Delta>]- Percent Nverify Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of nverify operations.
[-open-pct <Counter with Delta>]- Percent Open Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of open operations.
[-opattr-pct <Counter with Delta>]- Percent OpenAttr Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of openattr operations.
[-opconf-pct <Counter with Delta>]- Percent OpenConf Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of openconf operations.
[-opndg-pct <Counter with Delta>]- Percent OpenDowng Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of opendowng operations.
[-putfh-pct <Counter with Delta>]- Percent PutFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of putfh operations.
[-putpfh-pct <Counter with Delta>]- Percent PutPubFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of putpubfh operations.
[-putrfh-pct <Counter with Delta>]- Percent PutRootFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of putrootfh operations.
[-read-pct <Counter with Delta>]- Percent Read Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of read operations.
[-readdr-pct <Counter with Delta>]- Percent ReadDir Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readdir operations.
[-rlink-pct <Counter with Delta>]- Percent ReadLink Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readlink operations.
[-remove-pct <Counter with Delta>]- Percent Remove Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of remove operations.
[-rename-pct <Counter with Delta>]- Percent Rename Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of rename operations.
[-renew-pct <Counter with Delta>]- Percent Renew Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of renew operations.
[-restfh-pct <Counter with Delta>]- Percent RestoreFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of restorefh operations.
[-savefh-pct <Counter with Delta>]- Percent SaveFh Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of savefh operations.
[-secinf-pct <Counter with Delta>]- Percent SecInfo Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of secinfo operations.
[-sattr-pct <Counter with Delta>]- Percent SetAttr Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setattr operations.
[-sclid-pct <Counter with Delta>]- Percent SetCliId Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setcliid operations.
[-scidc-pct <Counter with Delta>]- Percent SetCliIdConf Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setcliidconf operations.
[-verify-pct <Counter with Delta>]- Percent Verify Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of verify operations.
[-write-pct <Counter with Delta>]- Percent Write Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of write operations.
[-relown-pct <Counter with Delta>]- Percent RelLockOwn Operations-
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of rellockown operations.
The following example displays statistics about the NFSv4 operations for a node named node1:
cluster1::> statistics-v1 nfs show-v4 -node node1 Node Value Delta Percent Ops Delta node1 ---------------------------success----------------------- Null Procs: 2 - 1% - Cmpnd Procs: 92 - - Access Ops: 16 - 6% - Close Ops: 8 - 3% - Commit Ops: 0 - 0% - Create Ops: 0 - 0% - Delpur Ops: 0 - 0% - Delrtn Ops: 0 - 0% - Getattr Ops: 76 - 27% - Getfh Ops: 22 - 8% - Link Ops: 0 - 0% - Lock Ops: 0 - 0% - Lockt Ops: 0 - 0% - Locku Ops: 0 - 0% - Lookup Ops: 13 - 5% - Lookupp Ops: 0 - 0% - Nverify Ops: 0 - 0% - Open Ops: 8 - 3% - Openattr Ops: 0 - 0% - Openconf Ops: 0 - 0% - Opendowng Ops: 0 - 0% - Putfh Ops: 92 - 32% - Putpubfh Ops: 0 - 0% - Putrootfh Ops: 2 - 1% - Read Ops: 0 - 0% - Readdir Ops: 2 - 1% - Readlink Ops: 0 - 0% - Remove Ops: 5 - 2% - Rename Ops: 3 - 1% - Renew Ops: 0 - 0% - Restorefh Ops: 11 - 4% - Savefh Ops: 13 - 5% - Secinfo Ops: 0 - 0% - Setattr Ops: 8 - 3% - Setclid Ops: 1 - 0% - Setclidconf Ops: 1 - 0% - Verify Ops: 0 - 0% - Write Ops: 3 - 1% - Rlockown Ops: 0 - 0% - Total Ops: 286 - Node Value Delta Percent Ops Delta node1 ---------------------------failure----------------------- Null Procs: 0 - 0% - Cmpnd Procs: 0 - - Access Ops: 0 - 0% - Close Ops: 0 - 0% - Commit Ops: 0 - 0% - Create Ops: 0 - 0% - Delpur Ops: 0 - 0% - Delrtn Ops: 0 - 0% - Getattr Ops: 0 - 0% - Getfh Ops: 0 - 0% - Link Ops: 0 - 0% - Lock Ops: 0 - 0% - Lockt Ops: 0 - 0% - Locku Ops: 0 - 0% - Lookup Ops: 5 - 63% - Lookupp Ops: 0 - 0% - Nverify Ops: 0 - 0% - Open Ops: 2 - 25% - Openattr Ops: 0 - 0% - Openconf Ops: 0 - 0% - Opendowng Ops: 0 - 0% - Putfh Ops: 0 - 0% - Putpubfh Ops: 0 - 0% - Putrootfh Ops: 0 - 0% - Read Ops: 0 - 0% - Readdir Ops: 0 - 0% - Readlink Ops: 0 - 0% - Remove Ops: 0 - 0% - Rename Ops: 0 - 0% - Renew Ops: 0 - 0% - Restorefh Ops: 0 - 0% - Savefh Ops: 0 - 0% - Secinfo Ops: 0 - 0% - Setattr Ops: 1 - 13% - Setclid Ops: 0 - 0% - Setclidconf Ops: 0 - 0% - Verify Ops: 0 - 0% - Write Ops: 0 - 0% - Rlockown Ops: 0 - 0% - Total Ops: 8 - Node Value Delta Percent Ops Delta node1 --------------------------- all ----------------------- Null Procs: 2 - 1% - Cmpnd Procs: 92 - - Access Ops: 16 - 5% - Close Ops: 8 - 3% - Commit Ops: 0 - 0% - Create Ops: 0 - 0% - Delpur Ops: 0 - 0% - Delrtn Ops: 0 - 0% - Getattr Ops: 76 - 26% - Getfh Ops: 22 - 7% - Link Ops: 0 - 0% - Lock Ops: 0 - 0% - Lockt Ops: 0 - 0% - Locku Ops: 0 - 0% - Lookup Ops: 18 - 6% - Lookupp Ops: 0 - 0% - Nverify Ops: 0 - 0% - Open Ops: 10 - 3% - Openattr Ops: 0 - 0% - Openconf Ops: 0 - 0% - Opendowng Ops: 0 - 0% - Putfh Ops: 92 - 31% - Putpubfh Ops: 0 - 0% - Putrootfh Ops: 2 - 1% - Read Ops: 0 - 0% - Readdir Ops: 2 - 1% - Readlink Ops: 0 - 0% - Remove Ops: 5 - 2% - Rename Ops: 3 - 1% - Renew Ops: 0 - 0% - Restorefh Ops: 11 - 4% - Savefh Ops: 13 - 4% - Secinfo Ops: 0 - 0% - Setattr Ops: 9 - 3% - Setclid Ops: 1 - 0% - Setclidconf Ops: 1 - 0% - Verify Ops: 0 - 0% - Write Ops: 3 - 1% - Rlockown Ops: 0 - 0% - Total Ops: 294 -
