ONTAP 9.10.1 commands
network subnet delete
Delete an existing subnet object
Delete a subnet that contains no ports.
-ipspace <IPspace> - IPspace Name
The IPspace to which the subnet belongs.
-subnet-name <subnet name> - Subnet Name
The name of the subnet to be deleted.
[-force-update-lif-associations <true>] - Change the subnet association
This command will fail if the subnet has ranges containing any existing service processor interface or network interface IP addresses. Setting this value to true will remove the network interface associations with the subnet and allow the command to succeed. However, it will not affect service processor interfaces.
The following example deletes subnet s1 in IPspace Default .
cluster1::> network subnet delete -ipspace Default -subnet-name s1
