system controller environment show
Display the FRUs in the controller
The system controller environment show displays information about all environment FRUs in the cluster. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported. By default, the command displays the following information about the environment FRUs in the cluster:
  • Node
  • FRU name
  • FRU state
To display more details, use the -instance parameter.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays detailed information about the environment FRUs.
[-node {<nodename>|local}] - Node
Selects information about all the environment FRUs that the specified node owns.
[-serial-number <text>] - FRU Serial Number
Selects information about all the environment FRUs with the specified serial number.
[-fru-name <text>] - FRU Name
Selects information about the environment FRU with the specified FRU name.
[-type {controller|psu|fan|dimm|bootmedia|ioxm|nvram|nvdimm}] - FRU Type
Selects information about all the environment FRUs with the specified FRU type.
[-name <text>] - Name
Selects information about all the environment FRUs with the specified unique name.
[-state <text>] - FRU State
Selects information about all the environment FRUs with the specified FRU state.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}] - Status
Selects information about all the environment FRUs with the specified health monitor status.
[-display-name <text>] - Display Name for the FRU
Selects information about all the environment FRUs with the specified display name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example|ethernet-switch}] - Monitor Name
Selects information about all the environment FRUs with the specified monitor.
[-model <text>] - Model Type
Selects information about all the environment FRUs with the specified FRU model.
[-shared {shared|not_shared}] - Shared Resource
Selects information about all the environment FRUs with the specified sharing type.
[-chassis-id <text>] - Chassis ID
Selects information about all the environment FRUs in the specified chassis.
[-additional-info <text>] - Additional Information About the FRU
Selects information about all the environment FRU with specified additional information.
[-seq-state-cnt <integer>] - Count of Same State
Selects information about all the environment FRU with specified sequential state count.
The following example displays information about all major environment FRUs in the cluster:
cluster1::> system controller environment show
Node               FRU Name                       State
node1              PSU1 FRU                       GOOD
node1              PSU2 FRU                       GOOD
node2              PSU1 FRU                       GOOD
node2              PSU2 FRU                       GOOD
The following example displays detailed information about a specific environment FRU:
cluster1::> system controller environment show -node node1 -fru-name "PSU1 FRU" -instance
Node: node1
                   FRU Serial Number: XXT122737891
                            FRU Name: PSU1 FRU
                            FRU Type: psu
                           FRU State: GOOD
                              Status: ok
            Display Name for the FRU: PSU1 FRU
                        Monitor Name: controller
                          Model Type: none
                     Shared Resource: shared
                          Chassis ID: 4591227214
Additional Information About the FRU: Part Number: 114-00065+A0
Revision: 020F
Manufacturer: NetApp
FRU Name: PSU
