network options detect-switchless-cluster show
Display the status of switchless cluster detection
The network options detect-switchless-cluster show command displays whether switchless cluster detection is enabled.
The following example displays whether switchless cluster detection is enabled:
      cluster1::*> network options detect-switchless-cluster show
      Enable Detect Switchless Cluster: true
