security login domain-tunnel delete
Delete authentication tunnel Vserver for administrative Vserver
The security login domain-tunnel delete
command deletes the tunnel established by the security login domain-tunnel create command. An error message will be generated if no tunnel exists.
The following command deletes the tunnel established by security login domain-tunnel create .
cluster1::> security login domain-tunnel delete
