ONTAP commands
vserver fcp topology show
Show FCP topology interconnect elements
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver
Use this parameter to select the interconnect elements for the specified Vservers.
[-lif <text>] - LIF Name
Use this parameter to select the interconnect elements for the specified FCP LIFs.
[-domain-id <integer>] - Domain Identifier
Use this parameter to select the interconnect elements with the specified domain identifier
[-logical-name <text>] - Logical Name
Use this parameter to select the interconnect elements with the specified logical name
[-vendor <text>] - Vendor
Use this parameter to select the interconnect elements with the specified vendor
[-release <text>] - Release
Use this parameter to select the interconnect elements with the specified release
[-wwn <text>] - World Wide Name
Use this parameter to select the interconnect elements with the specified World Wide Name
[-port-count <integer>] - Port Count
Use this parameter to select the interconnect elements with the specified port count
cluster1::> vserver fcp topology show
                       Domain Logical                                    Port
Vserver Lif Name       Id     Name                WWN                    Count
vs1     lif1
                       98     ssan-fc0e-fit-01    20:05:00:05:73:bd:a3:01 15
                       99     ssan-fc0e-d38       20:05:8c:60:4f:04:f1:01 11
                       112    ssan-fc0e-5         20:05:00:0d:ec:ca:0b:41 19
                       119    ssan-fc0e-core-a    20:05:54:7f:ee:02:c1:01 18
                       159    ssan-fc0e-7         20:05:00:05:9b:24:6e:c1 38
                       169    sdev-fc0e-gg26      20:05:54:7f:ee:31:06:81 53
                       174    ssan-fc0e-d46       20:05:00:05:9b:7d:f8:01 16
                       177    ssan-fc0e-e49       20:05:54:7f:ee:ef:1c:81 19
                       180    ssan-fc0e-d40       20:05:00:05:9b:79:a3:c1 20
vs1     lif2
                       229    ssan-fc0e-6         20:05:00:05:73:c8:8f:01 33
                       233    ssan-fc0e-e45       20:05:54:7f:ee:a0:67:01 8
11 entries were displayed.
The example above show FCP topology interconnect information for the cluster.
