ONTAP commands
system node power show
Display the current power status of the nodes
This command displays the power status of the main controller in each node across the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
This optional parameter specifies the name of a node for which information is to be displayed. If this parameter is not specified, the command displays information about all nodes in the cluster.
[-status {on|off}] - Current Power Status
If the -status parameter is specified, the command only lists information about the node with the power status value you enter.
The following example displays power status of all the nodes in cluster1.
cluster1::> system node power show
Node             Status
node1            on
node2            on
2 entries were displayed.
cluster1::>
