The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system configuration backup create
PDF of this doc site
Creating your file...
Your file is ready
Create a configuration backup
The system configuration backup create
command creates a new configuration backup file.
-node {<nodename>|local}
- Node (privilege: advanced)-
Use this parameter to specify the node on which to create the backup file.
[-backup-name <text>]
- Backup Name (privilege: advanced)-
Use this parameter to specify the name of the backup file to create. The backup name cannot contain a space or any of the following characters: * ? /
[-backup-type {node|cluster}]
- Backup Type (privilege: advanced)-
Use this parameter to specify the type of backup file to create.
The following example creates a a new cluster configuration backup file called node1.special.7z
on the node node1
cluster1::*> system configuration backup create -node node1 -backup-name node1.special.7z -backup-type cluster [Job 194] Job is queued: Cluster Backup OnDemand Job.
