ONTAP commands
snaplock event-retention show
Show status of Event Based Retention operation
The snaplock event-retention show command displays the status of an Event Based Retention (EBR) operation. Information about completed operations will be cleaned up after an hour after completion. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter is specified, the command displays all EBR operations that match the specified Vserver.
[-operation-id <integer>] - Operation ID
If this parameter is specified, the command displays all EBR operations that match the specified operation ID.
[-volume <volume name>] - Volume Name
If this parameter is specified, the command displays all EBR operations that match the specified volume. The parameter specifies the volume on which EBR operation is running or has completed.
[-path <text>] - Path
If this parameter is specified, the command displays all EBR operations that match the specified path. The parameter specifies the path on which EBR operation is running or has completed.
[-policy-name <text>] - Policy Name
If this parameter is specified, the command displays all EBR operations that match the specified policy name. The parameter specifies the EBR policy name.
[-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Retention Period
If this parameter is specified, the command displays all EBR operations that match the specified retention period. The parameter specifies the retention period of the EBR policy.
[-num-files-processed <integer>] - Number of Files Processed
If this parameter is specified, the command displays all EBR operations that match the specified number of processed files. The parameter specifies the number of files on which EBR policy was applied successfully.
[-num-files-failed <integer>] - Number of Files Failed
If this parameter is specified, the command displays all EBR operations that match the specified number of failed files. The parameter specifies the number of files on which the application of EBR policy failed.
[-num-files-skipped <integer>] - Number of Files Skipped
If this parameter is specified, the command displays all EBR operations that match the specified number of skipped files. The parameter specifies the number of files on which the application of EBR policy was skipped. A file that is under legal-hold will be skipped. If the retention time of a file is being shortened as a result of applying the EBR policy, that file will also be skipped.
[-num-inodes-ignored <integer>] - Number of Inodes Ignored
If this parameter is specified, the command displays all EBR operations that match the specified number of ignored inodes. The parameter specifies the number of inodes on which the application of EBR policy was not attempted because they were not regular files.
[-operation-status {Unknown|In-Progress|Failed|Aborting|Completed}] - Operation Status
If this parameter is specified, the command displays all EBR operations that match the specified operation status. The parameter specifies the operation status of an EBR operation.
[-status-details <text>] - Status Details
If this parameter is specified, the command displays all EBR operations that match the specified status details. The parameter specifies the status details of an EBR operation.
The following examples show the status of EBR operations for Vserver "vs1" and volume "slc" and the status of event-retention operation for operation ID 16842753 respectively.
vs1::*> snaplock event-retention operation show -volume slc
            Operation ID   Vserver         Volume          Operation Status
            16842753       vs1             slc             Completed
            16842754       vs1             slc             In-progress
vs1::*> snaplock event-retention operation show -operation-id 16842753
Operation ID: 16842753
                    Vserver: vs1
                     Volume: slc
                       Path: /vol/slc/d1
                Policy Name: p1
           Retention Period: 10 years
  Number of Files Processed: 50
     Number of Files Failed: 0
   Number of Inodes Ignored: 2
           Operation Status: Completed
             Status Details: No error
