The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume flexgroup qtree-disable
PDF of this doc site
Creating your file...
Your file is ready
Disable qtree support on a FlexGroup
The volume flexgroup qtree-disable
command disables qtree support on a FlexGroup.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver in which the FlexGroup is located.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the name of the FlexGroup.
The following example disables the qtree support on a FlexVol named "fg" in Vserver "vs0":
cluster::*> volume flexgroup qtree-disable -vserver vs0 -volume fg
