volume flexgroup qtree-disable
Disable qtree support on a FlexGroup
The volume flexgroup qtree-disable
command disables qtree support on a FlexGroup.
-vserver <vserver name>
- Vserver Name (privilege: advanced)-
This specifies the Vserver in which the FlexGroup is located.
-volume <volume name>
- Volume Name (privilege: advanced)-
This specifies the name of the FlexGroup.
The following example disables the qtree support on a FlexVol named "fg" in Vserver "vs0":
cluster::*> volume flexgroup qtree-disable -vserver vs0 -volume fg
