The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs users-and-groups local-group modify
PDF of this doc site
Creating your file...
Your file is ready
Modify a local group
The vserver cifs users-and-groups local-group modify
command modifies the description of a local group.
-vserver <vserver name>
- Vserver-
This specifies the name of the Vserver.
-group-name <CIFS name>
- Group Name-
This specifies the name of the local group.
[-description <TextNoCase>]
- Description-
This specifies a description for this local group. If the description contains a space, enclose the parameter in quotation marks.
The following example modifies the description of the local group "CIFS_SERVER\g1" associated with Vserver "vs1".
cluster1::> vserver cifs users-and-groups local-group modify -vserver vs1 -group-name CIFS_SERVER\g1 -description "Example Description"
