storage aggregate object-store revert-object-format show
Display the progress of format revert in a FabricPool aggregate
The `storage aggregate object-store revert-object-format show ` command displays information about the status of the unified object format revert in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate-name <text>]- Aggregate Name-
If this parameter is specified, the command displays information about the status of unified format revert process running on the specified aggregates.
[-obj-store-name <text>]- ONTAP Name for this Object Store Config-
If this parameter is specified, the command displays information about the status of unified format revert for objects in the object store whose name matches the specified names.
The following example displays status of all object format revert operation in the cluster:
cluster1::>storage aggregate object-store revert-object-format show
