snaplock event-retention policy modify
- PDF of this doc site
Creating your file...
Your file is ready
Modify SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy modify
command is used to modify the retention period of an Event Based Retention (EBR) policy for a Vserver. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
Specifies the name of the Vserver for which retention period of a policy needs to be modified.
-name <text>
- Policy Name-
Specifies the name of the EBR policy for which the retention period needs to be modified.
[-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]
- Event Retention Period-
Specifies the new value of retention period.
The following example modifies the retention period of policy "p1" for Vserver "vs1" to "5 years"
vs1::> snaplock event-retention policy modify -name p1 -retention-period "5 years"
