qos statistics volume resource cpu show
Display CPU resource utilization data per volume
The qos statistics volume resource cpu show command displays the CPU utilization for volumes per node.
The command displays the following data:
The QoS volume name (Workload)
The QoS workload ID (ID)
CPU utilization observed in percentage (CPU)
The results displayed per iteration are sorted by total CPU utilization. Each iteration starts with a row that displays the total CPU utilization across all volumes.
-node {<nodename>|local}- Node-
Selects the volumes that match this parameter value.
[-rows <integer>]- Number of Rows in the Output -
Specifies the number of busiest QoS policy groups to display. The default setting is 10. The allowed range of values is 1 to 20.
-vserver <vserver name>- Vserver Name -
Specifies the Vserver to which the volume belongs.
-volume <volume name>- Volume Name }-
Selects the CPU utilization data that match this parameter value. Enter a complete volume name or press the <Tab> key to complete the name. Wildcard query characters are not supported.
[-iterations <integer>]- Number of Iterations-
Specifies the number of times the display is refreshed before terminating. If you do not specify this parameter, the command iterates until interrupted by Ctrl-C.
[-refresh-display {true|false}]- Toggle Screen Refresh Between Each Iteration-
Specifies the display style. If true, the command clears the display after each data iteration. If false, the command displays each data iteration below the previous one. The default is false.
[-show-flexgroup-as-constituents {true|false}]- Display Flexgroups as Constituents-
If the parameter is specified and if the value is true, it will display data for FlexVols and Flexgroup Constituents. Otherwise it will display data for FlexVols and Flexgroups.
cluster1::> qos statistics volume resource cpu show -node nodeA -iterations 100 -rows 3
Workload ID CPU
--total- (100%) - 9%
vs0vol1-wid-102 102 5%
vs0vol2-wid-121 121 2%
vs2_vol0-wid-.. 212 2%
-total- (100%) - 8%
vs2_vol0-wid-.. 212 1%
The example above displays total CPU utilization for the 3 volumes with the highest CPU utilization and it refreshes the display 100 times before terminating.
cluster1::> qos statistics volume resource cpu show -node local -vserver vs0 -volume vs0_vol1 -iterations 100
Workload ID CPU
-total- (100%) - 2%
vs0_vol1-wid7.. 7916 2%
-total- (100%) - 2%
-total- (100%) - 1%
vs0_vol1-wid7.. 7916 1%
-total- (100%) - 2%
-total- (100%) - 2%
The example above displays total CPU utilization for volume vs0_vol1 in Vserver vs0 and it refreshes the display 100 times before terminating.
