      snaplock compliance-clock ntp modify
Modify SnapLock ComplianceClock synchronization setting
The snaplock compliance-clock ntp modify command modifies the option to enable or disable the SnapLock ComplianceClock synchronization with the system time. The ComplianceClock is synchronized only when an NTP server has been configured so that the system time follows the NTP time and the skew between the ComplianceClock time and the system time is greater than 1 day.
[-is-sync-enabled {true|false}]- Enable ComplianceClock sync to NTP system time (privilege: advanced)-
Specifies whether synchronization should be enabled or not. This is a cluster wide option.
cluster1::> snaplock compliance-clock ntp modify -is-sync-enabled true
