ONTAP commands
qos adaptive-policy-group delete
Delete an adaptive policy group
The qos adaptive-policy-group delete command deletes an adaptive policy group from a cluster. You cannot delete a policy group if a QoS workload associated with a storage object is assigned to it unless you use the -force parameter. Using the -force parameter will delete all the QoS workloads for storage objects associated with the specified adaptive policy groups .
Only user created adaptive policy groups can be deleted. Default adaptive policy groups are read only and cannot be deleted.
-policy-group <text> - Name
Specifies the name of the adaptive policy group that you want to delete.
[-force <true>] - Force Delete Workloads for the QoS adaptive policy group (privilege: advanced)
Specifies whether to delete an adaptive policy group along with any underlying workloads.
The following example deletes "p1" adaptive policy group:
cluster1::> qos adaptive-policy-group delete p1
Deletes the "p1" adaptive policy group along with any underlying QoS workloads.
cluster1::> qos adaptive-policy-group delete p1 -force
Looking for answers?
Try Doc, our Gen AI Assistant.
