security key-manager external show
Show the set of configured external key management servers.
This command displays the external key management servers configured on the cluster for a given Vserver. No entries are displayed when external key management is not enabled for the given Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If you specify this parameter, then the command displays the key management servers for only the given Vserver.
[-key-server <text>]- Key Server Name with port-
If you specify this parameter, then the command displays only the given key management server with the given host name or IP address listening on the given port.
[-client-cert <text>]- Name of the Client Certificate-
If you specify this parameter, then the command displays only the key management servers using a client certificate with the given name.
[-server-ca-certs <text>,…]- Names of the Server CA Certificates-
If you specify this parameter, then the command displays only the key management servers using server-ca certificates with the given names.
[-timeout <integer>]- Server I/O Timeout-
If you specify this parameter, then the command displays only the key management servers using the given I/O timeout.
[-username <text>]- Authentication User Name-
If you specify this parameter, then the command displays only the key management servers using the given authentication username.
[-policy <text>]- Security Policy-
If you specify this parameter, then the command displays only the key management servers using the given key manager policy.
The following example lists all configured key management servers for all Vservers:
cluster-1::> security key-manager external show
Vserver: datavs
Client Certificate: datavsClientCert
Server CA Certificates: datavsServerCaCert1, datavsServerCaCert2
Security Policy: IBM_Key_Lore
Key Server
keyserver.datavs.com:5696
Vserver: cluster-1
Client Certificate: AdminClientCert
Server CA Certificates: AdminServerCaCert
Security Policy:
Key Server
10.0.0.10:1234
fd20:8b1e:b255:814e:32bd:f35c:832c:5a09:1234
ks1.local:1234
4 entries were displayed.
The following example lists all configured key management servers with more detail, including timeouts and usernames:
cluster-1::> security key-manager external show -instance
Vserver: datavs
Key Server: keyserver.datavs.com:5696
Timeout: 25
Username: datavsuser
Vserver: cluster-1
Key Server: 10.0.0.10:1234
Timeout: 25
Username:
Security Policy:
Vserver: cluster-1
Key Server: fd20:8b1e:b255:814e:32bd:f35c:832c:5a09:1234
Timeout: 25
Username:
Security Policy:
Vserver: cluster-1
Key Server: ks1.local:1234
Timeout: 45
Username:
Security Policy:
