The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system ha interconnect ood enable-statistics
PDF of this doc site
Creating your file...
Your file is ready
Enable detailed statistics collection
The system ha interconnect ood enable-statistics
command enables collection of the statistics on the out-of-order delivery-capable high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
-node <nodename>
- Node (privilege: advanced)-
This mandatory parameter specifies which node will have the statistics collection enabled. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood enable-statistics -node ic-f2554-03
