system ha interconnect ood enable-statistics
Enable detailed statistics collection
The system ha interconnect ood enable-statistics
command enables collection of the statistics on the out-of-order delivery-capable high-availability interconnect device. This command is only supported on FAS2500 series nodes in the cluster.
-node <nodename>
- Node (privilege: advanced)-
This mandatory parameter specifies which node will have the statistics collection enabled. The value "local" specifies the current node.
cluster1::*> system ha interconnect ood enable-statistics -node ic-f2554-03
