ONTAP commands
network interface service-policy delete
Delete an existing service policy
The network interface service-policy delete command deletes an existing service policy.
-vserver <vserver name> - Vserver
Use this parameter to specify the name of the Vserver of the service policy to be deleted.
-policy <text> - Policy Name
Use this parameter to specify the name of the service policy to be deleted.
The following example shows the deletion of a service policy.
cluster1::> network interface service-policy show -vserver cluster1
Vserver   Policy                     Service: Allowed Addresses
cluster1
          custom                     intercluster-core: 0.0.0.0/0
                                     management-ssh: 0.0.0.0/0
                                     management-https: 0.0.0.0/0
default-intercluster       intercluster-core: 0.0.0.0/0
default-management         management-core: 0.0.0.0/0
                                     management-autosupport: 0.0.0.0/0
default-route-announce     management-bgp: 0.0.0.0/0
4 entries were displayed.
cluster1::> network interface service-policy delete -vserver cluster1 -policy custom
cluster1
3 entries were displayed.
