network connections active show-protocols
Show a count of the active connections by protocol
The network connections active show-protocols command displays the number of active connections per protocol, organized by node.
The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>]- Vserver-
This parameter is used by the system to break down the output per vserver.
[-proto {UDP|TCP}]- Protocol-
Use this parameter to display information only about the connections that use the network protocol you specify. Possible values include tcp (TCP), udp (UDP), and NA (not applicable).
[-count <integer>]- Client Count-
Use this parameter to display only protocols with the number of active client connections you specify.
The following example displays information about all network protocols being used by active connections:
cluster1::> network connections active show-protocols
Node Vserver Name Protocol Count
node0
vs1 UDP 19
vs1 TCP 11
vs2 UDP 17
node1
vs1 UDP 14
vs2 TCP 10
