Command reference
network connections active show-protocols
Show a count of the active connections by protocol
The network connections active show-protocols command displays the number of active connections per protocol, organized by node.
Note The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Use this parameter to display information only about the connections on the node you specify.
[-vserver <vserver>] - Vserver
This parameter is used by the system to break down the output per vserver.
[-proto {UDP|TCP|TLS|RDMA}] - Protocol
Use this parameter to display information only about the connections that use the network protocol you specify. Possible values include tcp (TCP), udp (UDP), and NA (not applicable).
[-count <integer>] - Client Count
Use this parameter to display only protocols with the number of active client connections you specify.
The following example displays information about all network protocols being used by active connections:
cluster1::> network connections active show-protocols
Node     Vserver Name    Protocol   Count
node0
         vs1             UDP            19
         vs1             TCP            11
         vs2             UDP            17
node1
         vs1             UDP            14
         vs2             TCP            10
