statistics nfs show-v3
Display NFSv3 statistics
The statistics nfs show-v3 command displays the following statistics about the NFSv3 operations on each node in the cluster:
Result of the operations (success or failure)
Total number of null operations
Total number of getattr operations
Total number of setattr operations
Total number of lookup operations
Total number of access operations
Total number of readsymlink operations
Total number of read operations
Total number of write operations
Total number of create operations
Total number of mkdir operations
Total number of symlink operations
Total number of mknod operations
Total number of remove operations
Total number of rmdir operations
Total number of rename operations
Total number of link operations
Total number of readdir operations
Total number of readdirplus operations
Total number of fsstat operations
Total number of fsinfo operations
Total number of pathconf operations
Total number of commit operations
Total number of nfsv3 operations
Percent of null operations
Percent of getattr operations
Percent of setattr operations
Percent of lookup operations
Percent of access operations
Percent of readsymlink operations
Percent of read operations
Percent of write operations
Percent of create operations
Percent of mkdir operations
Percent of symlink operations
Percent of mknod operations
Percent of remove operations
Percent of rmdir operations
Percent of rename operations
Percent of link operations
Percent of readdir operations
Percent of readdirplus operations
Percent of fsstat operations
Percent of fsinfo operations
Percent of pathconf operations
Percent of commit operations
This command is designed to be used to analyze performance characteristics and to help diagnose issues.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node
If you specify this parameter, the command displays NFSv3 statistics only for the specified node.
- [-result {success|failure|all}]- Result
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified result (success/failure/all).
- [-null <Counter with Delta>]- Null Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of null operations.
- [-gattr <Counter with Delta>]- GetAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of getattr operations.
- [-sattr <Counter with Delta>]- SetAttr Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of setattr operations.
- [-lookup <Counter with Delta>]- LookUp Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of lookup operations.
- [-access <Counter with Delta>]- Access Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of access operations.
- [-rsym <Counter with Delta>]- ReadSymlink Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readsymlink operations.
- [-read <Counter with Delta>]- Read Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of read operations.
- [-write <Counter with Delta>]- Write Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of write operations.
- [-create <Counter with Delta>]- Create Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of create operations.
- [-mkdir <Counter with Delta>]- MkDir Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of mkdir operations.
- [-symln <Counter with Delta>]- SymLink Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of symlink operations.
- [-mknod <Counter with Delta>]- MkNod Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of mknod operations.
- [-remove <Counter with Delta>]- Remove Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of remove operations.
- [-rmdir <Counter with Delta>]- RmDir Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of rmdir operations.
- [-rename <Counter with Delta>]- Rename Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of rename operations.
- [-link <Counter with Delta>]- Link Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of link operations.
- [-rdir <Counter with Delta>]- ReadDir Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readdir operations.
- [-rdirp <Counter with Delta>]- ReadDirPlus Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of readdirplus operations.
- [-fsstat <Counter with Delta>]- FsStat Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of fsstat operations.
- [-fsinfo <Counter with Delta>]- FsInfo Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of fsinfo operations.
- [-pconf <Counter with Delta>]- PathConf Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of pathconf operations.
- [-commit <Counter with Delta>]- Commit Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of commit operations.
- [-total <Counter64 with Delta>]- Total Operations
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified number of total NFSv3 operations.
- [-null-pct <Counter with Delta>]- Percent Null Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of null operations.
- [-gattr-pct <Counter with Delta>]- Percent GetAttr Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of getattr operations.
- [-sattr-pct <Counter with Delta>]- Percent SetAttr Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of setattr operations.
- [-lookup-pct <Counter with Delta>]- Percent LookUp Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of lookup operations.
- [-access-pct <Counter with Delta>]- Percent Access Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of access operations.
- [-rsym-pct <Counter with Delta>]- Percent ReadSymlink Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readsymlink operations.
- [-read-pct <Counter with Delta>]- Percent Read Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of read operations.
- [-write-pct <Counter with Delta>]- Percent Write Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of write operations.
- [-create-pct <Counter with Delta>]- Percent Create Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of create operations.
- [-mkdir-pct <Counter with Delta>]- Percent MkDir Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of mkdir operations.
- [-symln-pct <Counter with Delta>]- Percent SymLink Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of symlink operations.
- [-mknod-pct <Counter with Delta>]- Percent MkNod Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of mknod operations.
- [-remove-pct <Counter with Delta>]- Percent Remove Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of remove operations.
- [-rmdir-pct <Counter with Delta>]- Percent RmDir Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of rmdir operations.
- [-rename-pct <Counter with Delta>]- Percent Rename Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of rename operations.
- [-link-pct <Counter with Delta>]- Percent Link Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of link operations.
- [-rdir-pct <Counter with Delta>]- Percent ReadDir Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readdir operations.
- [-rdirp-pct <Counter with Delta>]- Percent ReadDirPlus Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of readdirplus operations.
- [-fsstat-pct <Counter with Delta>]- Percent FsStat Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of fsstat operations.
- [-fsinfo-pct <Counter with Delta>]- Percent FsInfo Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of fsinfo operations.
- [-pconf-pct <Counter with Delta>]- Percent PathConf Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of pathconf operations.
- [-commit-pct <Counter with Delta>]- Percent Commit Ops
If you specify this parameter, the command displays statistics only about the node or nodes that have the specified percentage of commit operations.
The following example displays statistics about the NFSv3 operations for a node named node1:
cluster1::> statistics nfs show-v3 -node node1 Node Value Delta Percent Ops Delta node1 ---------------------------success----------------------- Null Ops: 4 - 7% - GetAttr Ops: 10 - 19% - SetAttr Ops: 2 - 4% - Lookup Ops: 2 - 4% - Access Ops: 14 - 26% - ReadSymlink Ops: 0 - 0% - Read Ops: 0 - 0% - Write Ops: 0 - 0% - Create Ops: 2 - 4% - MkDir Ops: 1 - 2% - Symlink Ops: 0 - 0% - MkNod Ops: 0 - 0% - Remove Ops: 1 - 2% - RmDir Ops: 0 - 0% - Rename Ops: 0 - 0% - Link Ops: 0 - 0% - ReadDir Ops: 2 - 4% - ReadDirPlus Ops: 10 - 19% - FsStat Ops: 1 - 2% - FsInfo Ops: 5 - 9% - PathConf Ops: 0 - 0% - Commit Ops: 0 - 0% - Total Ops: 54 - Node Value Delta Percent Ops Delta node1 ---------------------------failure----------------------- Null Ops: 0 - 0% - GetAttr Ops: 0 - 0% - SetAttr Ops: 0 - 0% - Lookup Ops: 2 - 100% - Access Ops: 0 - 0% - ReadSymlink Ops: 0 - 0% - Read Ops: 0 - 0% - Write Ops: 0 - 0% - Create Ops: 0 - 0% - MkDir Ops: 0 - 0% - Symlink Ops: 0 - 0% - MkNod Ops: 0 - 0% - Remove Ops: 0 - 0% - RmDir Ops: 0 - 0% - Rename Ops: 0 - 0% - Link Ops: 0 - 0% - ReadDir Ops: 0 - 0% - ReadDirPlus Ops: 0 - 0% - FsStat Ops: 0 - 0% - FsInfo Ops: 0 - 0% - PathConf Ops: 0 - 0% - Commit Ops: 0 - 0% - Total Ops: 2 - Node Value Delta Percent Ops Delta node1 --------------------------- all ----------------------- Null Ops: 4 - 7% - GetAttr Ops: 10 - 18% - SetAttr Ops: 2 - 4% - Lookup Ops: 4 - 7% - Access Ops: 14 - 25% - ReadSymlink Ops: 0 - 0% - Read Ops: 0 - 0% - Write Ops: 0 - 0% - Create Ops: 2 - 4% - MkDir Ops: 1 - 2% - Symlink Ops: 0 - 0% - MkNod Ops: 0 - 0% - Remove Ops: 1 - 2% - RmDir Ops: 0 - 0% - Rename Ops: 0 - 0% - Link Ops: 0 - 0% - ReadDir Ops: 2 - 4% - ReadDirPlus Ops: 10 - 18% - FsStat Ops: 1 - 2% - FsInfo Ops: 5 - 9% - PathConf Ops: 0 - 0% - Commit Ops: 0 - 0% - Total Ops: 56 -
 PDFs
PDFs
