lun portset remove
Remove iSCSI/FCP LIFs from a portset
This command removes a LIF from a portset.
You cannot remove the last LIF in a portset if the portset is bound to an initiator group (igroup). To remove the last LIF in a portset, use the lun igroup unbind command to unbind the portset from the igroup. Then you can remove the last LIF in the portset.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
-portset <text> - Portset Name
Specifies the portset you want to remove a LIF from.
-port-name <port_name>,…​ - LIF or TPG Name
Specifies the LIF name you want to remove from the portset.
cluster1::> portset remove -vserver vs1 -portset ps1 -port-name lif1
Removes port lif1 from portset ps1 on Vserver vs1.
