lun portset remove
Remove iSCSI/FCP LIFs from a portset
This command removes a LIF from a port set.
You cannot remove the last LIF in a port set if the port set is bound to an initiator group (igroup). To remove the last LIF in a port set, use the lun igroup unbind command to unbind the port set from the igroup. Then you can remove the last LIF in the port set.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-portset <text>
- Portset Name-
Specifies the port set you want to remove a LIF from.
-port-name <port_name>,…
- LIF or TPG Name-
Specifies the LIF name you want to remove from the port set.
cluster1::> port set remove -vserver vs1 -portset ps1 -port-name lif1
Removes port lif1 from port set ps1 on Vserver vs1.
