lun maxsize
Display the maximum possible size of a LUN on a given volume or qtree.
This command returns the maximum size of LUNs for different OS types in a volume or qtree. The command also includes possible maximum size for LUNs with Snapshots or without Snapshots. You can specify the path of the volume or qtree to determine the maximum size of a LUN that you want to create within that volume or qtree.
If you do not specify a path, the command returns the maximum LUN size for each OS type for all volumes and qtrees in a cluster.
The available space in a volume can change over time which means that the size reported by lun maxsize can change as well. In addition, the maximum LUN size allowed in a lun resize command may be less than the size reported by lun maxsize .
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Specifies the Vserver.
[-path <qtree path>]- Volume or Qtree Path -
Specifies the path of the root volume or qtree. Examples of correct LUN paths are
/vol/vol1/lun1and/vol/vol1/qtree1/lun1. - |
[-volume <volume name>]- Volume Name -
Specifies the volume that contains the LUN you want to get the maximum size for.
[-qtree <qtree name>]- Qtree Name }-
Specifies the qtree that contains the LUN you want to get the maximum size for.
[-t, -ostype <text>]- OS Type-
Specifies the OS type for the new LUN. + On an All SAN Array, the following OS types are supported:
aix - the LUN will be used with AIX.
hyper_v - the LUN will be used with Microsoft Hyper-V.
linux - the LUN will be used with Linux.
vmware - the LUN will be used with VMware VMFS.
windows - the LUN will be used with Microsoft Windows.
+ On all other clusters, the following OS types are supported:
hpux - the LUN will be used with HP-UX.
netware - the LUN will be used with NetWare.
openvms - the LUN will be used with Open-VMS.
solaris - the LUN will be used with Solaris slice partitioning.
solaris_efi - the LUN will be used with Solaris EFI partitioning.
windows - the LUN will be used with a Master Boot Record (MBR) partition table on Microsoft Windows 2003 or earlier.
windows_2008 - the LUN will be used with Microsoft Windows 2008 or later.
windows_gpt - the LUN will be used with a GUID Partition Type (GPT) partition table on Microsoft Windows.
xen - the LUN will be used with Xen
[-complete-ss-reserve <size>]- With Complete Snapshot Reserve-
Shows the maximum size possible of a LUN if you have the complete Snapshot reserve enabled.
[-ss-reserve <size>]- With Snapshot Reserve-
Shows the maximum size possible of a LUN if you have the Snapshot reserve enabled.
[-without-ss-reserve <size>]- Without Snapshot Reserve-
Shows the maximum size possible of a LUN if you have no Snapshot reserve enabled.
cluster1::> lun maxsize -vserver vs1 -volume vol1 -ostype linux Virtual Without With SS Complete Server Volume Qtree OS Type SS Reserve Reserve SS Reserve ---------- ------------ ------------ -------- ---------- --------- ---------- vs1 vol1 "" linux 45MB 45MB 45MB
Displays the maximum size of a LUN for the OS type linux.
Vserver Volume Qtree OS Type SS Reserve Reserve SS Reserve
vs1 vol1 "" aix 178MB 178MB 178MB
hpux 178MB 178MB 178MB
hyper_v 172.6MB 172.6MB 172.6MB
linux 178MB 178MB 178MB
netware 178MB 178MB 178MB
openvms 178MB 178MB 178MB
solaris 178MB 178MB 178MB
solaris_efi 178MB 178MB 178MB
windows 172.6MB 172.6MB 172.6MB
windows_2008
windows_gpt 172.6MB 172.6MB 172.6MB
xen 178MB 178MB 178MB
12 entries were displayed.
Displays the maximum size of LUNs for all OS types on volume vol1.
