security key-manager show-key-store
Displays the configured key manager key stores.
This command displays the list of configured key managers.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, then the command will list the key manager configured for the given Vserver.
[-key-store <Key Store>]- Key Store-
If you specify this parameter, then the command displays only the vservers that have the given key-store configured.
The following example shows all configured key managers in the cluster. In the example, the admin vserver has onboard key management configured and the data vserver "datavs1" has external key management configured:
cluster-1::> security key-manager show-key-store Vserver Key Store ---------------------- --------- cluster-1 onboard datavs1 external
