security login role create
Add an access control role
The security login role create command creates an access-control role. An access-control role consists of a role name and a command or directory to which the role has access. It optionally includes an access level (none, readonly, or all) and a query that applies to the specified command or command directory. After you create an access-control role, you can apply it to a management-utility login account by using the security login modify or security login create commands.
-vserver <Vserver Name>- Vserver-
This optionally specifies the Vserver name associated with the role.
 -role <text>- Role Name-
This specifies the role that is to be created.
 -cmddirname <text>- Command / Directory-
This specifies the command or command directory to which the role has access. To specify the default setting, use the special value "`DEFAULT` ".
 [-access <Access>]- Access Level-
This optionally specifies an access level for the role. Possible access level settings are none, readonly, and all. The default setting is
all. [-query <query>]- Query-
This optionally specifies the object that the role is allowed to access. The query object must be applicable to the command or directory name specified by -cmddirname. The query object must be enclosed in double quotation marks (""), and it must be a valid field name.
The following command creates an access-control role named "admin" for the vs1.example.com Vserver. The role has all access to the "volume" command but only within the "aggr0" aggregate.
cluster1::> security login role create -role admin -cmddirname volume -query "-aggr aggr0" -access all -vserver vs1.example.com
