system node hardware tape library show
Display information about tape libraries
This command displays the following information about tape libraries:
Node to which the tape library is attached
Device ID of the tape library
Description of the tape library
NDMP path of the tape library
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Displays detailed information about tape libraries on the specified node.
[-device-id <text>]- Device ID-
Selects information about the tape library that has the specified device ID.
[-description <text>]- Description-
Selects information about the tape library or libraries that have the specified description.
[-wwn <text>]- World Wide Name-
Selects information about the tape library that has the specified worldwide name.
[-serial-number <text>]- Serial Number-
Selects information about the tape library that has the specified serial number.
[-ndmp-path <text>]- NDMP Path-
Selects information about the tape library or libraries that have the specified NDMP path.
The following example displays information about all tape libraries attached to the cluster:
cluster1::> system node hardware tape library show
Node Device Id Drive Description NDMP Path
cluster1-00
0b.125L1 HP MSL G3 mc1
Series
0c.125L1 HP MSL G3 mc0
Series
2 entries were displayed.
