vserver vscan on-demand-task unschedule
Unschedule an On-Demand task
The vserver vscan on-demand-task unschedule command unschedules an On-Demand task.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver on which you want to unschedule an On-Demand task.
-task-name <text> - Task Name
This parameter specifies the name of the On-Demand task that you want to unschedule.
The following example unschedules an On-Demand task:
cluster1::> vserver vscan on-demand-task unschedule -vserver vs1 -task-name t1
cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1
Vserver: vs1
                         Task Name: t1
                List of Scan Paths: /test
             Report Directory Path: /report
                      Job Schedule: -
Max File Size Allowed for Scanning: 2GB
            File Paths Not to Scan: /vol1/cold-files/
       File Extensions Not to Scan: mp3, mp4
           File Extensions to Scan: *
      Scan Files with No Extension: true
           Request Service Timeout: 1m
                    Cross Junction: true
               Directory Recursion: true
                     Scan Priority: low
                  Report Log Level: verbose
