system smtape status show
Show status of SMTape sessions
This command lists the status of all SMTape sessions in the cluster. By default, this command lists the following information:
Session
Type
Status
Progress
Path
Device
Node
[-fields <fieldname>,…] -
Use this parameter to display additional fields about each session apart from the default entries. This parameter is optional. Any combination of the following fields is valid:
Session
Node
Type
Status
Path
Device
Progress
Start-time
End-time
Update-time
Backup-snapshot
Tape-block-size
[-instance ]} -
Displays detailed information about the specified sessions.
 [-session <Sequence Number>]- Session Identifier-
Selects information about a specific SMTape session. A Session Identifier is a number that is used to identify a particular SMTape session.
 [-node {<nodename>|local}]- Node Name-
Selects information about sessions related to the specified node.
 [-type {backup|restore}]- Operation Type-
Selectsinformation about SMTape sessions of the specified operation type.
 [-status {COMPLETED|FAILED|ACTIVE|WAITING|ABORTING|UNKNOWN}]- Session Status-
Selects information about SMTape sessions having the specified status in the parameter.
 [-path <text>]- Path Name-
Selects information about SMTape sessions on a volume which is at the specified path name. This is the logical path of the volume and you must specify the path name in the following format: /
vserver_name/volume_name. [-device <text>]- Device Name-
Selects information about the SMTape sessions on the specified tape device. You must specify the tape device name in the following format: /
node_name/tape_device. [-progress {<integer>[KB|MB|GB|TB|PB]}]- Bytes Transferred-
Selects information about SMTape sessions in which the number of data bytes transferred in a particular session matches with the number specified in this parameter.
 [-start-time <MM/DD/YYYY HH:MM:SS>]- Start Time-
Selects information about SMTape sessions whose starting time matches the specified starting time.
 [-end-time <MM/DD/YYYY HH:MM:SS>]- End Time-
Selects information about SMTape sessions whose ending time matches the specified ending time.
 [-backup-snapshot <snapshot name>]- Snapshot Name-
Selects information about SMTape sessions that use a particular Snapshot copy name which matches the specified Snapshot copy name in the parameter in backup or restore operations.
 [-tape-block-size <integer>]- Tape Block Size-
Selects information about SMTape sessions that use a particular tape block size which matches the specified tape block size parameter in backup or restore operations.
 [-error <text>]- Error Description-
Selects information about SMTape sessions that have a particular error description which matches the specified error description in the parameter.
Displays default entries about the five SMTape sessions.
cluster1::> system smtape status show Session Type Status Progress Path Device Node ------- ------- --------- -------- ------------ --------------- ----------- 5 Backup COMPLETED 50MB /vsrvr1/vol1 /cls1-01/nrst0l cluster1-01 4 Restore FAILED 0B /vsrvr1/vol3 /cls1-02/nrst2l cluster1-02 3 Backup COMPLETED 50MB /vsrvr1/vol3 /cls1-01/nrst0l cluster1-01 2 Backup COMPLETED 50MB /vsrvr1/vol2 /cls1-03/nrst0m cluster1-03 1 Backup COMPLETED 50KB /vsrvr1/vol5 /cls1-01/nrst0n cluster1-01 5 entries were displayed.
The following example shows the output with the -instance argument.
cluster1::> system smtape status show -instance
Session Identifier: 1
         Node Name: node1
    Operation Type: Backup
            Status: COMPLETED
         Path Name: /vs1/vol1
       Device Name: /node1/rst0a
 Bytes Transferred: 2048
        Start Time: 1/4/2012 14:26:24
          End Time: 1/4/2012 14:29:45
      Last updated: 1/4/2012 14:29:45
     Snapshot Name: vol1.snapshot
   Tape Block Size: 240
 Error Description: None
