storage aggregate object-store profiler show
Show Object Store Profiler Status
The storage aggregate object-store profiler show command is used to monitor progress and results of the storage aggregate object-store profiler start command.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node <nodename>]- Node Name (privilege: advanced)-
This parameter specifies the node on which the profiler was started.
[-object-store-name <text>]- ONTAP Name for this Object Store Configuration (privilege: advanced)-
This parameter specifies the object store configuration that describes the object store. The object store configuration has information about the object store server name, port, access credentials, and provider type.
[-profiler-status <text>]- Profiler Status (privilege: advanced)-
Current status of the profiler.
[-start-time <MM/DD/YYYY HH:MM:SS>]- Profiler Start Time (privilege: advanced)-
Time at which profiler run started.
[-op-name <text>]- Operation Name - PUT/GET (privilege: advanced)-
Name of the operation. Possible values are PUT or GET.
[-op-size {<integer>[KB|MB|GB|TB|PB]}]- Size of Operation (privilege: advanced)-
Size of the PUT or GET operation.
[-op-count <integer>]- Number of Operations Performed (privilege: advanced)-
Number of operations issued to the object store.
[-op-failed <integer>]- Number of Operations Failed (privilege: advanced)-
Number of operations that failed.
[-op-latency-minimum <integer>]- Minimum Latency for Operation in Milliseconds (privilege: advanced)-
Minimum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-maximum <integer>]- Maximum Latency for Operation in Milliseconds (privilege: advanced)-
Maximum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-average <integer>]- Average Latency for Operation in Milliseconds (privilege: advanced)-
Average latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-throughput {<integer>[KB|MB|GB|TB|PB]}]- Throughput per Second for the operation (privilege: advanced)-
Throughput per second for the operation.
[-op-errors <text>,…]- Error Reasons and Count (privilege: advanced)-
Error reasons and count for failed operation.
[-op-latency-histogram <text>,…]- Latency Histogram (privilege: advanced)-
Latency histogram for the operation.
The following example displays the results of storage aggregate object-store profiler start :
cluster1::>storage aggregate object-store profiler show
