storage aggregate object-store profiler show
Show Object Store Profiler Status
The storage aggregate object-store profiler show command is used to monitor progress and results of the storage aggregate object-store profiler start command.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node Name
This parameter specifies the node on which the profiler was started.
[-object-store-name <text>] - ONTAP Name for this Object Store Configuration
This parameter specifies the object store configuration that describes the object store. The object store configuration has information about the object store server name, port, access credentials, and provider type.
[-profiler-status <text>] - Profiler Status
Current status of the profiler.
[-start-time <MM/DD/YYYY HH:MM:SS>] - Profiler Start Time
Time at which profiler run started.
[-op-name <text>] - Operation Name - PUT/GET
Name of the operation. Possible values are PUT or GET.
[-op-size {<integer>[KB|MB|GB|TB|PB]}] - Size of Operation
Size of the PUT or GET operation.
[-op-count <integer>] - Number of Operations Performed
Number of operations issued to the object store.
[-op-failed <integer>] - Number of Operations Failed
Number of operations that failed.
[-op-latency-minimum <integer>] - Minimum Latency for Operation in Milliseconds
Minimum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-maximum <integer>] - Maximum Latency for Operation in Milliseconds
Maximum latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-latency-average <integer>] - Average Latency for Operation in Milliseconds
Average latency of the operation in milliseconds, as measured from the filesystem layer.
[-op-throughput {<integer>[KB|MB|GB|TB|PB]}] - Throughput per Second for the operation
Throughput per second for the operation.
[-op-errors <text>,…​] - Error Reasons and Count
Error reasons and count for failed operation.
[-op-latency-histogram <text>,…​] - Latency Histogram
Latency histogram for the operation.
The following example displays the results of storage aggregate object-store profiler start :
cluster1::>storage aggregate object-store profiler show
