vserver cifs domain name-mapping-search remove
Remove from the list of trusted domains for name-mapping search
The vserver cifs domain name-mapping-search remove command removes one or more trusted domains from the list used by the specified Vserver to lookup Windows user names when performing Windows user to UNIX user name-mapping. If a list of trusted domains is not provided, the entire trusted domain list for the specified Vserver is removed. This command is not supported for workgroup CIFS servers.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver from which you want to remove trusted domains.
[-trusted-domains <domain name>,…​] - Trusted Domains
This parameter specifies a comma-delimited list of trusted domains of the home domain.
The following example removes two trusted domains from the list used by Vserver vs1:
cluster1::> vserver cifs domain name-mapping-search remove -trusted-domains cifs1.example.com, cifs2.example.com
