storage bridge coredump show
Display a list of bridge coredumps
The storage bridge coredump show command displays information about all the coredump files previously retrieved with the storage bridge coredump collect command. If no parameters are specified, the default command displays the following information about the coredump files:
Bridge Name
Bridge Serial Number
Coredump Filename
Located on Node
Panic Timestamp
Panic String
To display detailed information about a single coredump file, use the -node and -corename parameters.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-serial-number <text>]- Bridge Serial Number-
Use this parameter to select the coredump files from the storage bridge that matches the specified bridge serial number.
[-corename <text>]- Coredump Filename-
Use this parameter to select the coredump files that matches the specified file name.
[-name <text>]- Bridge Name-
Use this parameter to select the coredump files from the storage bridge that matches the specified bridge name.
[-node <nodename>]- Located on Node-
Use this parameter to select the coredump the coredump files that are located on the specified node.
[-panic-time <MM/DD/YYYY HH:MM:SS>]- Panic Timestamp-
Use this parameter to select the coredump files that were collected at the specified time.
[-panic-string <text>]- Panic String-
Use this parameter to select the coredump files that matches the specified panic string.
The following example displays information about all coredump files:
cluster1::> storage bridge coredump show
Bridge Name: ATTO_FibreBridge7500N_1
Bridge Serial Number: FB7500N100018
Coredump Filename: core.FB7500N100018.1970-01-05.17_50_30.mem
Located on Node: stg-8020-6a
Panic Timestamp: 7/6/2017 11:03:37
Panic String: CoreDumpGenerate CLI Command
cluster1::>
