storage array show
Display information about SAN-attached storage arrays.
The storage array show command displays information about arrays visible to the cluster. If no parameters are specified, the command displays the following information about all storage arrays:
Prefix
Name
Vendor
Model
Options To display detailed information about a single array, use the `-name` parameter. The detailed view adds the following information:
Serial Number
Optimization Policy
Affinity
Errors
Path Failover Time
Extend All Path Failure Event
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-name <text>]- Name
Selects the arrays that match this parameter value.
- [-prefix <text>]- Prefix
Abbreviation for the named array.
- [-vendor <text>]- Vendor
Array manufacturer.
- [-model <text>]- Model
Array model number.
- [-options <text>]- options
Vendor specific array settings.
- [-serial-number <text>]- Serial Number
Array product identifier.
- [-max-queue-depth <integer>]- Target Port Queue Depth (privilege: advanced)
- [-lun-queue-depth <integer>]- LUN Queue Depth (privilege: advanced)
- [-optimization-policy {iALUA|eALUA|symmetric|proprietary|mixed|unknown}]- Optimization Policy
- [-affinity {none|aaa|ap|mixed|unknown}]- Affinity
- [-error-text <text>,…]- Error Text
- [-is-upgrade-pending {true|false}]- Upgrade Pending (privilege: advanced)
- [-path-failover-time <integer>]- Path Failover Time (sec)
Use this parameter to list arrays that have path failover time set to the value you specify.
- [-all-path-fail-delay <integer>]- Extend All Path Failure Event (secs)
Use this parameter to list arrays that have the all path failure event delay set to the value you specify.
The following example displays information about all arrays.
cluster1::> storage array show
Prefix                         Name   Vendor            Model Options
                   HITACHI_DF600F_1  HITACHI           DF600F
                         IBM_1722_1      IBM             1722
2 entries were displayed.
The following example displays detailed information about a specific array:
cluster1::> storage array show -name HITACHI_DF600F_1
                                 Prefix: abc
                                 Vendor: HITACHI
                                  Model: DF600F
                                options:
                          Serial Number: 4291000000000000
                    Optimization Policy: iALUA
                               Affinity: aaa
                             Error Text:
            Path Failover Timeout (sec): 30
   Extend All Path Failure Event (secs): 50
 PDFs
PDFs
