network ndp default-router show
Display default routers
The network ndp default-router show command displays Neighbor Discovery Protocol (NDP) default routers learned on a specified port.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Displays the NDP default routers from the specified node.
- [-ipspace <IPspace>]- IPspace name (privilege: advanced)
Displays the NDP default routers from the specified IPspace.
- [-port {<netport>|<ifgrp>}]- Port (privilege: advanced)
Displays the NDP default routers from the specified port.
- [-router-addr <IP Address>]- Router Address (privilege: advanced)
Displays the default routers that have the specified IPv6 addresses.
- [-flag {none|managed-address-DHCPv6|other-DHCPv6}]- Flag (privilege: advanced)
Displays the default routers that have the specified flag. The flag indicates whether addresses are available via DHCPv6 or other configuration information is available via DHCPv6.
- [-expire-time {[<integer>d][<integer>h][<integer>m][<integer>s]|never|expired}]- Expire Time (privilege: advanced)
Displays the default routers that have the specified expire time.
The following example displays NDP default routers on local port e0f.
cluster1::*> network ndp default-router show -port e0f -node local Node: node1 IPspace: Default Port Router Address Flag Expire Time -------- -------------------------- -------------- -------------- e0f fe80::5:73ff:fea0:107 none 0d0h23m9s
 PDFs
PDFs
