security certificate show-generated
Display ONTAP generated certificates
This command displays information about the Data ONTAP generated digital digital certificates. Some details are displayed only when you use the command with the -instance parameter.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Name of Vserver-
Selects the Vserver whose digital certificates you want to display.
[-common-name <FQDN or Custom Common Name>]- FQDN or Custom Common Name-
Selects the certificates that match this parameter value.
[-serial <text>]- Serial Number of Certificate-
[-ca <text>]- Certificate Authority-
[-type <type of certificate>]- Type of Certificate-
[-subtype <kmip-cert>]- (DEPRECATED)-Certificate Subtype-
This parameter has been deprecated in ONTAP 9.6 and may be removed in a future release of Data ONTAP. Selects the certificate subtype that matches the specified value. The valid values are as follows:
kmip-cert- this is a Key Management Interoperability Protocol (KMIP) certificate
[-cert-name <text>]- Unique Certificate Name-
This specifies the system's internal identifier for the certificate. It is unique within a Vserver.
[-size <size of requested certificate in bits>]- Size of Requested Certificate in Bits-
[-start <Date>]- Certificate Start Date-
[-expiration <Date>]- Certificate Expiration Date-
[-public-cert <certificate>]- Public Key Certificate-
[-country <text>]- Country Name-
[-state <text>]- State or Province Name-
[-locality <text>]- Locality Name-
[-organization <text>]- Organization Name-
[-unit <text>]- Organization Unit-
[-email-addr <mail address>]- Contact Administrator's Email Address-
[-protocol <protocol>]- Protocol-
[-hash-function <hashing function>]- Hashing Function-
[-self-signed {true|false}]- Self-Signed Certificate-
[-is-root {true|false}]- Is Root CA Certificate?-
The examples below display information about Data ONTAP generated digital certificates.
cluster1::> security certificate show-generated
Vserver Serial Number Certificate Name Type
vs0 4F4E4D7B www.example.com server
Certificate Authority: www.example.com
Expiration Date: Thu Feb 28 16:08:28 2013
cluster1::> security certificate show-generated -instance
Vserver: vs0
Certificate Name: www.example.com
FQDN or Custom Common Name: www.example.com
Serial Number of Certificate: 4F4E4D7B
Type of Certificate: server
Size of Requested Certificate(bits): 2048
Certificate Start Date: Fri Apr 30 14:14:46 2010
Certificate Expiration Date: Sat Apr 30 14:14:46 2011
Public Key Certificate: -----BEGIN CERTIFICATE-----
MIIDfTCCAmWgAwIBAwIBADANBgkqhkiG9w0BAQsFADBgMRQwEgYDVQQDEwtsYWIu
YWJjLmNvbTELMAkGA1UEBhMCVVMxCTAHBgNVBAgTADEJMAcGA1UEBxMAMQkwBwYD
VQQKEwAxCTAHBgNVBAsTADEPMA0GCSqGSIb3DQEJARYAMB4XDTEwMDQzMDE4MTQ0
BgNVHQ8BAf8EBAMCAQYwHQYDVR0OBBYEFCVG7dYGe51akE14ecaCdL+LOAxUMA0G
CSqGSIb3DQEBCwUAA4IBAQBJlE51pkDY3ZpsSrQeMOoWLteIR+1H0wKZOM1Bhy6Q
+gsE3XEtnN07AE4npjIT0eVP0nI9QIJAbP0uPKaCGAVBSBMoM2mOwbfswI7aJoEh
+XuEoNr0GOz+mltnfhgvl1fT6Ms+xzd3LGZYQTworus2
-----END CERTIFICATE-----
Country Name (2 letter code): US
State or Province Name (full name): California
Locality Name (e.g. city): Sunnyvale
Organization Name (e.g. company): example
Organization Unit (e.g. section): IT
Email Address (Contact Name): web@example.com
Protocol: SSL
Hashing Function: SHA256
