network tcpdump show
Show running tcpdump instances
The network tcpdump show command shows currently running packet traces (via tcpdump) on a matching node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Use this parameter optionally to show the details of running packet traces on a matching node.
[-port {<netport>|<ifgrp>}]- Port-
Use this parameter optionally to show the details of running packet trace on a matching network interface.
The following example shows the details of running packet traces on nodes "node1" and "node2":
cluster1::> network tcpdump show
Node Port
node1
e0a
node2
e0c
