cluster identity modify
- PDF of this doc site
Creating your file...
Modify the cluster's attributes
The cluster identity modify
command changes a cluster's identity information.
[-name <Cluster name>]
- Cluster Name-
Use this parameter to specify a new name for the cluster.
The name must contain only the following characters: A-Z, a-z, 0-9, "-" or "_".
The first character must be one of the following characters: A-Z or a-z.
The last character must be one of the following characters: A-Z, a-z or 0-9.
The maximum supported length is 44 characters.
The system reserves the following names: "all", "cluster", "local" and "localhost".
[-location <text>]
- Cluster Location-
Use this parameter to specify the physical location of the cluster. For example, "Lab 5".
[-contact <text>]
- Cluster Contact-
Use this parameter to specify contact information for the cluster, such as a name or e-mail address.
The following example renames the current cluster to cluster2
cluster1::> cluster identity modify -name cluster2
