The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage aggregate efficiency cross-volume-dedupe stop
PDF of this doc site
Creating your file...
Your file is ready
Stops the cross volume background deduplication on an aggregate
The storage aggregate cross-volume-dedupe stop
command is used to stop cross volume background deduplication on an aggregate.
-aggregate <aggregate name>
- Aggregate (privilege: advanced)-
This specifies the aggregate on which cross volume background deduplication should be stopped. If no aggregate is specified then it will stop on all aggregates
The following example displays information for stopping cross volume background deduplication on aggregate "aggr1":
cluster:::> storage aggregate efficiency cross-volume-dedupe stop -aggregate aggr1 The efficiency operation on aggregate "aggr1" is being stopped.
